Butterfly Wind Vector
Hi everyone,
I’m a researcher from KADK and I’m testing Butterfly for a comparison between CFD tools.
I’m trying to rotate wind vector, but after a certain angle (approximately near 30° clockwise) it doesn’t run. SnappyHexMesh gives this error:
  1. Solution exception:
    --> snappyHexMesh Failed!
    --> FOAM FATAL ERROR:
    Point (10 40 7.5) is not inside the mesh or on a face or edge.
    Bounding box of the mesh:(-14.8394 -70.31135 0) (62.35048 36.99024 15)
From function static Foam::labelList Foam::refinementParameters::findCells(bool, const Foam::polyMesh&, const pointField&)
in file snappyHexMeshDriver/refinementParameters/refinementParameters.C at line 206.
FOAM exiting
There’s anyone that knows how to solve this?
In attachment the screenshot, gh definition and 3dm file.
Thanks in advance,
Federico
20170505__.3dm (206 KB)
test_butterfly_20170505__.gh (429 KB)
Based on the error, and without looking to your model, you need to set the locationInMesh to a point inside the domain. It’s currently outside the bounding box.
Hi Mostapha,
thank you very much, I didn’t check the meshing parameters component.
Regards
Federico
