Hello, How to calculate the heating and daylight intensity (Lux) of skylights that have a simple or complex design? Similar to the following examples… How can I calculate and analyze with Honey bee? thank you…IAG_LS_2_2012|535x500
@tahmineh.j, The image is not uploaded correctly. You need to spend some time on the forum and read the posts before being able to post an image.
Generally speaking you can use Honeybee for both cases. For daylight studies you can use a grid-based recipe to calculate illuminance values in lux. To study the effect of skylight on cooling and heating you need to set up an energy model which again can be done by Honeybee.
