California Solar Irradiance Map using google earth
This is a very interesting application this guys at http://solar.ucsd.edu/c/ used Google earth maps to plot a solar irr…
Might interest some of you
http://solar.ucsd.edu/c/blog/ (go to the end of the blog)
enjoy
claudio
Hi Claudio,
I couldn’t find the project. Is it running somewhere live?
Mostapha
Mostapha,
Tyr This one http://solar.ucsd.edu/c/california-solar-irradiance-map/
Dowland the kmz file and it Will open google earth if its installed in your computer.
You Can also try This one: http://solar.ucsd.edu/c/benefits-of-optimum-geometric-alignment-of-…
Again you need to have Google Earth installed
Once you have the file opened in Google Earth look at the right side of the UI under the places tab. You’ll get all the options to visualize the data
Hope it helps
claudio
