I’ve got the top four floors of a building that i’m working on set up in HB. If I run only one floor through OpenStudio, it runs fine. Same thing with three floors. Not a problem. Each floor is more or less a copy of the other so the codes aren’t really changing from one the other.
As soon as I hook up a fourth floor though, rhino crashes when I toggle OpenStudio. In each case solveadjacencies works so I feel like I’m missing something. I partially suspect it is my computer/ram getting maxed out but that doesn’t seem all too realistic. I feel like it would take more for 32gbs to get maxed out.
Zack
Upload To HB Grasshopper File.gh (3.06 MB)
Hi Zach,
I checked this file. First, you need to solve one surface that must be intersected between 2 zones.
Omid.
UploadToHBGrasshopperFile_OMDMR .gh (3.08 MB)
Omid,
Thanks for checking it out.
The air wall is an easy fix but even with that mistake Openstudio still runs when only 3 floors are connected. As soon as I hook up the fourth floor, Rhino Crashes on me. I’m curios if you had the same result.
Zack,
That works for me(I removed that zone).
For test-simulation, it is better to remove unnecessary output. Check the last attachments.
please let me know when this issue is finally fixed.
-Omid
That did the trick. Thanks alot Omid
Omid,
Without taking up too much of your time, would you have any idea why my problem keeps persisting? I thought I had it fixed but rhino keeps crashing as soon as I go from 3 floors to 4 floors. I’ve relink/reset most of the code and geometry but nothing seems to change.
Is there a limit maybe to how many zones you can plug into HB?
