Now i can use honeybee in dynamo, but i want to use it directly int Revit.
Hi @zzg, Welcome to the forum. In theory you should be able to do so but we don’t currently have a plugin for Revit. You need to create one but you can copy/ paste most of the code from the Dynamo plugin.
