Cannot find function file
Previously everything was working fine however now I am getting this weird error.
Does anyone have any ideas?
Much Appreciated!
Hi Anton,
If I am not mistaken, the .cal file gets written by gencumulativesky.exe, which should be in the ladybug root folder. Can you get it to launch through cmd prompt?
Sarith
What Sarith said. I just checked your example and it runs with no issues.
I attached both .sky and ,call file that should be generated under (C:\ladybug\skylib\cumulativeSkies\Houston_Ellington_Afb_)
cumulativeSky_1_1_1_12_31_24.sky (238 Bytes)
Houston_Ellington_Afb__1.cal (2.92 KB)
Hi Sarith,
What do you mean launch it through the cmd prompt? Launch the cal file or the batch file again?
I think it’s something with Perkins + Will network. I had an issue with the same file, that worked on my home computer but not at P+W.
http://www.grasshopper3d.com/group/ladybug/forum/topics/error-w-hon…
Still haven’t found a solution.
S
Update: Our IT is telling me to try running GH using admin rights. I don’t have time to test this out now, but let me know if you have better luck. Did you ask your IT?
+1. Can you try to run the batch file as an administrator and see if that makes a difference?
Hi Anton,
I have had a crazy week so I could not reply earlier. I was just curious to know if you can get cumulativesky.exe to launch at all. As others pointed out, I guess issue should resolve if you launch it as admin. I have run across such issues with xform in Radiance.
Alright, finally got some time to test this out.
So, yes, the problem is resolved if we use admin access. Specifically, I found the Toronto_cumulativeSky.bat batch file, ran it as an admin, and that fixes everything.
Thanks guys.
