it only showed a wrong message as
“1. Solution exception:Access to the path ‘C:\Users\zheng_radAnalysis.sky’ is denied.”
Any idea to solve this kind of issue? I am using a school computer to run grasshopper instead of my own tower.
Looks like the sky file is created in c:\users which is not a place that the component can have access. If you connect a different path to Ladybug_Ladybug component the default directory will change and then the sky files will be written to the same directory. That should solve your problem.
