Change "convection algorithm" in latest version
Hey dear forum!
You guys helped me a lot over the past weeks and months and I am very happy about that! Here is my question:
I would like to change the convection alogrithm in honeybee. In legacy there used to be the HoneybeeSetZoneProperties. Is there anything equal to that in the latest version?
By looking at the IDF file I found out, that the algorithm is set to TARP and DOE-2, which is fine. But I would like to try other options.
Could you help me with the input? Maybe I have to plug something into the add_str of my OSM. But really, I am not able to find the right input.
Thanks in advance!
Kay
Here we go, I figured it out:
SurfaceConvectionAlgorithm:Inside,
Simple;
!- Simple = constant value natural convection (ASHRAE)
!- TARP = variable natural convection based on temperature difference (ASHRAE, Walton)
!- CeilingDiffuser = ACH-based forced and mixed convection correlations for ceiling diffuser configuration with simple natural convection limit
!- AdaptiveConvectionAlgorithm = dynamic selection of convection models based on conditions
!- ASTMC1340 = mixed convection correlations based on heat flow direction, surface tilt angle, surface characteristic length, and air speed past the surface.
SurfaceConvectionAlgorithm:Outside,
SimpleCombined;
!- SimpleCombined = Combined radiation and convection coefficient using simple ASHRAE model
!- TARP = correlation from models developed by ASHRAE, Walton, and Sparrow et. al.
!- MoWiTT = correlation from measurements by Klems and Yazdanian for smooth surfaces
!- DOE-2 = correlation from measurements by Klems and Yazdanian for rough surfaces
!- AdaptiveConvectionAlgorithm = dynamic selection of correlations based on conditions
