Changing the shape of EP Result component
Hi
As I connect these 2 components (image) the shape of EP Result component changes.
guide me plz
Looks like your energy simulation has failed. Check the report from runEnergyPlus component to find the reason.
No runEnergyPlus component doesn’t have any error.
As I connect these 2 components the shape of EP Result component changes. (even before starting to run)
Tim, It’s very hard to help you more w/o sharing an example file. I’m not sure what is going on with your file.
Tim,
It appears that you are not requesting any zone-level outputs from EnergyPlus. Set one of the inputs on the “Generate EP Output” component to True.
-Chris
