Child surface component update issue
probably a bug. If I update my childsrf-component, wether a geometry is connected or not: 1. Solution exception:name ‘_HBObj’ is not defined
I also opened a file, found in this forum, and updated that component, too. With the same results.
Help would be fine, thanks,
Daniel
link to the example file I updated the component:
http://www.grasshopper3d.com/group/ladybug/forum/topics/add-glazing…
my file attached.
update childsrf.gh (106 KB)
Daniel,
After the update you need to reinsert the HB_addHBGlz component.
See that the first input name changed. The updater can’t solve well those cases.
Yes, I did that, but the component I drag into the canvas is dated with february 2014 again…
Obviously only the components within the canvas get updated … ?
D
The UpdateAllObjects should do the trick. You set it to true. So it is weird that you still get the old version …
Hm…
I’ll try to set it up again completely. Let’s see what will happen.
Thx.
D
