Circular Pattern to Reduce Solar Gain Conficting with Surface
Hi Everyone,
It is my first time to use ladybug and I am facing some difficulties that I could not solve. I am trying to create bigger circles for harmful radiation and smaller circles for helpful radiation i.e. circular pattern to reduce solar gain on ETFE skin (reference: Responsive facade based on radiation results)
My first issue is the extreme negative result value for the net solar benefit. I am not sure if there is an error in the data that caused such a negative value (-660435).
My second problem is the circles on the surface/geometry
The circles are cutting through the geometry. Is there a way to orient or to project them correctly onto the surface?
Thanks in advance!
Couldn’t upload the grasshopper file so using wetransfer: https://wetransfer.com/downloads/8fdff3481da615e674204fcbeee2b09620191010145648/c23e9151c69cefc0072a5ef1c8bfe5d720191010145648/83875d
Note: Plugins used to create geometry - Lunchbox and M+
