I don’t know where to get the logs but here’s a quick line I got out of it, what do you think Write/Read permission problem ?
PermissionError: [WinError 32] The process cannot access the file because it is being used by another process: ‘C:\Users\tlagarde\AppData\Local\Temp\tmpqnsuy_8g’
I got this problem too. I’m tring to use Accelerad to replace original radiance files. Once I add the hb radiance parameter, the same location can’t be accessed, it located in ‘C:\Users\username\AppData\Local\Temp\XXXXXXXXXXX’.
I searched this problem in the forum, and all people trigger this thing when they’re trying to do the radiance job. I’m wondering how to fix it.
