Hi there,
I’m trying to compute the sun vector with a vertical surface in order to identify where there could be a glare risks on a facade. For a reason that I ignore, the GH compute angle component is not returning the same angle (in degrees) as the angular dimension display component. I’m probably doing somethin wrong.
thank you in advance
1737_Raytrace_SunGlareRisk.gh (395.9 KB)
