Hi everyone.
i am using ladybug sunlight hours component for a specific period analyse and I should get “the average number of daily hours which at least 2sqm of floor area receive direct light”. I used LD mesh threshold selector but the result is wrong. i am so confused and i dont know which components should i use to calculate average daily hours.
I appreciate if anyone can explain how should i get this result,
First you have to separate the results for each day. You can use Branch Data for this part.
Then find out the number of hours that satisfies the target (area > 2). If the grid is uniform this will be easy and you can use points count, otherwise you need to get the area of mesh faces that each point represents.
