Good day to all, my simple task was trying to connect the image based simulation in HB to a VR 360 view somehow with all the light properties i have assigned using honeybee. is it possible to do so ? since the camera types available, as you know, are ( persp, parallel, fisheye).
what i wish to see is a HB rendered image but in VR with a 360 view ( to be able to rotate and see the whole space)
See @Nathaniel’s work on AcceleradRT and AcceleradVR. They are probably a better fit for what you are trying to do: https://nljones.github.io/Accelerad/rt.html#vr
