Context as a shading in Honeybe Run Daylight Simulation
Hi!
I am looking for a way to test building envelope to examine Daylight Autonomy with Honeybe Run Daylight Simulation component. Is it possible to introduce context geometry as a shading to observe it’s impact on the analysis result? When I connect it to HbRDS’s _HBObjects input as a HBSrf it sarts to calcuale, but takes forever.
Can anybody help with the problem?
Regards
Karol
Karol,
Will be more helpful if you upload the file in question.
Abraham,
Here it comes.
Tnanks!
Karol
HB_DA_CONTEXT_INTRO.gh (571 KB)
Karol,
Unfortunately didn’t find any way to speed up the process (but increasing the grid size). You did correctly. The annual analysis is time consuming, so it is what it is.
Abraham,
Tnank you for your time. Ill try to find another way to check context impact on this factor.
Karol
