I’m having trouble sizing the cooling system in my model. I would like to set the maximum capacity of the cooling system, and based on the component description for “HoneyBee HVAD Cooling Detail” i would think that the way to do that is by using the “coolingHardSize” input in the Cooling Detail component.
However, even if i set the maximum capacity to 0W the temperatures still don’t rise above 24C, which is the cooling setpoint.
So, my question is: How do I set the maximum capacity of the cooling system?
Thank you!
