Just wondering if i am doing this correctly. The project is set up in Millimeters and i think i have the correct sizing for everything. However, when i generate the area for the surface i am analyzing it seems to be bigger than what is indicated on rhino. (70 meters long and around around 12m tall at the tips)
Using the area computation i get 573580m2 for the area.
So i feel like i am not getting accurate results for the radiation analysis. The output is 299530 kW in a year. is there a way to easily see any mistakes?
I hope i am making sense.
Radiation analysis trial.gh (1.2 MB) (The attached file has the toggle set on false as the file is quite heavy)
