I am wondering if there is a way to differential plastic and metal with the same R,G, B, roughness, and specularity values in HB[+].
I have tried radMetalMaterial of HB legacy
However, it came out with an error, which is understandable as radMetalMaterial is a HB legacy component. Please see the below screenshot:
I don’t remember if we did or did not expose the metal material but in case we didn’t you can create your own material by modifying the component code. See here for another example:
