Using the create CSV Schedule component to generate a custom wind based infiltration schedule (because I can’t adjust the coefficients from Grasshopper, that is a whole other story).
The location of the CSV Schedule is correctly referenced in the Open Studio file, but when it runs, the results show zero infiltration in each zone. Yet when I switch the schedule to a typical one in OS, the zones show infiltration again. Any idea why it does not appear to like the hourly CSV schedule?
I have to say that it cannot be a bug in OpenStudio since honeybee legacy was developed at a time before OpenStudio supported CSV schedules and, to this day, it uses a workaround to add the CSV schedules in.
I second @mostapha 's suggestion that we will really need the grasshopper file to recreate the issue. Also, if you can verify that the CSV schedule name was correctly written into the IDF, that will narrow down the possible causes.
