I am doing some analysis where an apparatus tracks the sun.
I used the sun-path component to get me the sun-coordinates so that the normal vector to the tracking geometry keeps looking at the sun.
To go with this - this will be a HONEYBEE RADIATION ANALYSIS - I had created a cumulative sky component - however, for many days, this was giving me results that didn’t add up to some sanity checks.
Finally i realized the root cause today - the cumulative sky component does not work for intraday hourly intervals.
A surest test is - Radiation on Ground (12 to 16 hrs) != Radiation(12-14) + Radiation(14-16)
Also - the minimum interval at which cumulative sky works is 2 hours. I could have made peace with this, but if even that is giving incorrect values, what can be done?
Does anyone have any prior experience here?
A solution then - would be a point-in-time radiation study rather than a cumulative sky radiation study?
Radiation(0-24hrs) gives values which are correct - i could check them with the total solar insolation recieved that day, on online resources.
I cannot directly put the code here, as it has too much stuff related to the problem we trying to solve - if anyone requests, id need to put in a simpler stripped version.
