Hi, I’m not much familiar with Honeybee and I’m having some trouble with Honeybee energy simulation.
I can’t get any data from Honeybee_Read EP Result component for simulating a cylinder form. How can I fix it?
And one more thing, In what order the mass is divided into different zones? How can I understand each zone number is representing which part of the building?
An example file always helps us understand what issues you are having. It may also be that you are not requesting any zone-level outputs for the simulation.
Also, while HB can simulate curved geometry, it will usually take almost 10% time to run the simulation if you planarize it first.
Actually I watched your Ladybug tutorial videos on youtube and I used the example file in Ladybug Comfort Tutorials - Indoor Comfort PMV video. I was trying to use a cylinder form instead of the box to compare the results.
Thanks a lot for checking the file, I updated the components and the ReadEPResult component is working fine, but a new error has appeared in 3D Chart component:
You are using an old version of the component that was updated with the “Update Ladybug” component. To clarify, this process with Update Ladybug does not work when the inputs/outputs of the component have changed. In this case, the LegendPar input changed from List to Data Tree. You have to update such components by manually dragging the new one onto the canvas.
