Daylight error in iteration
Hello Everyone,
I am doing annual daylight analysis and it is working fine but I need to recompute the script or disable-enable the “analysis grid” component every time when I change something (WWR or Windows Shade Depth) in model otherwise it is giving this error, any suggestion please, because of this I am not able to automate the script and analysis. By replacing Annual daylight recipe with DC grid based daylight recipe solves the problem.
Did you set reuse input in recipe to False? It looks like you are reloading the results from the older study.
@mostapha Thank you sir but it still giving same problem, Here is my grasshopper file I am not able to identify mistake in the scrip or whether this problem is in my system.
.Daylight Test.gh (572.1 KB)
