hi all,
I was wondering if anyone had worked with a workflow to “convert” a daylight autonomy to a daylight factor.
If using (legacy) daysim method then each of your grid points have calculated a relationship to each of the 144 skypatches. There must be a way to “default” these skypatches to something similar to the cie overcast sky and then get the daylight factor results “for free” without having to raytrace again.
Similar must be possible with multiphase simulations.
thoughts?
