Hello!
I am doing daylight calculations with different window types, which i construct myself. However, changing tvis doesn’t seem to change the daylight factor result. Has anyone of you encountered this issue? Attached you can find a screenshot of the script and the file itself.
Moreover: Is there the possibility to change the reflectance of surfaces?
Thank you for any advice!
Best regards,
Toni
