Daylight factor not working?
Hi, I just started working with honeybee but I ran into a problem
I get 0% of daylight factor all the time, even when using a simple box.
Ideally I would like to use also the FRAMES object for shading, but connecting it gives me error
My honeybee component is orange - it says I do not have energy plus installed, even after installation
I am attaching my file
daylight factor.gh (1010 KB)
Hi Mateusz,
The problem is because test points are under the floor:
you should move your grid up.
You can also connect frames to your model.
Best
Antonello
Thank you, I will test it soon. Never thought that I positioned test grid wrong :smiley:
