Hello Mostapha,
Any idea why I get sometimes and for some gridSize,
the values at the corners in the very end of the room different than zero
as everything else around them?
Thanks a lot,
Dimitris
ADF_02.gh (179 KB)
Hello Mostapha,
Thanks a lot,
Dimitris
ADF_02.gh (179 KB)
Hi Dimitris,
This is a light leakage which is common if parameters are set lower than what it needs to be. Honeybee by default checks the inputs for parameters and set them to an acceptable minimum but looks like it wasn’t enough for this case. I used a higher quality [1] for radParameters and the results looks fine.
In the current version the parameters are set based on meter units. What was the units in your document?
Hello Mostapha,
Understood.
Thanks a lot!
The units are also meters in my document.
Dimitris
