Hello all ,
I am try to run a daylight simulation with the central type layout, with central layouts .
office daylighting error.gh (719.7 KB)
Thanks
Hello all ,
From the output error seems to be you are using chinese characters to define where to save or file name. This is a problem that was discussed in the past.
Change the location of the output to latin characters an dtry again.
I Modify the grid size to run normally.
