Default Values。。。
Excuse me does anybody know the default value that I underlined in this component??
This depends on your location , you can refer ASHRAE 55.
I found that if you don’t set a new value inside of this component, it has a default value inside of it. How can I see the default value??
Hi -
That doesn’t seem to be the case:
When you hover the mouse over an input, you will see the value in the pop-up.
-wim
Thank you very much!
If you don’t plug in a number these are all null and it looks like it’s going to work. So what parameters does it compute with?
Hi -
Inputs with an underscore behind the name are optional inputs (See # 4 in “HARD AND FAST RULES”).
I really don’t know.
-wim
Use the HB LabelZones and LabelSurfaces for that.
