Difference between a Aperture with a single face again a closed brep on a DaylightSim
Dear community,
I have a curiosity on how does Radiance work in Ladybug, when I want to run a daylight simulation, where a “Aperture” instead of being a single surface is a closed brep/element, as when I import an element from Revit?
Is the same thing and does not impact the simulation result or does the closed element waste an extra ambient bounce?
Thanks and best regards
To my knowledge, Radiance doesn’t except volumes. So a closed brep/element will be exploded into 6 separate surfaces, which will all be given the chosen property of the aperture. So if you’ve chosen an aperture with LT = 0,7, a ray will need to pass through both of large surfaces (the 2 windows panes), which will result in LTw = 0,7*0,7 = 0,49. So that’s a no go. You will need to remove the extra surfaces from the brep.
You can use my Rhino.Inside.Revit script as example of how to do this: GitHub - labrossemp/Rhino.Inside.Revit: Simple script to export geometry from Revit to Rhino
