Hello everybody!
During my simulations I noticed a big difference between the results generated in Honeybee and the results from the IDF file. I will put here the files I am developing.
MET - MODEL.gh (1.4 MB)
Hello everybody!
Can anybody help me?
Didn’t check the files, but i suggest you to check the loads in both IDF’s. Cooling and heating are close but lighting and equipment don’t. What i can infer from that is that the definitions are pretty much different on each idf. This checking requires sometime, and i think you should be the one that start doing this. After your checking we can help you better.
