I would like to seek your help in the following issue. I have a group of surfaces that I am analyzing by entering the grid size as the longest length of the edge of the surface because I would like to get the same surfaces after the analysis to filter based on KWh values.
However, after the analysis, I get the same number of meshes but a higher number of results or points due to which I cannot filter out the surfaces properly.
Could you please help me out with this problem? I would really appreciate it.
Thank you so much!
Problem1.gh (67.8 KB)
