Hello everyone.
I’m running daylight and energy analysis of a building which has different uses.
I would like to be able to set different occupancy periods/analysis periods based on the type of use. (commercial use: 10-19, residence 24hrs, ecc)
Is this possible somehow?
Thanks in advance
Hi @CamillaFranchini
I think this Hydra script will be of some use.
You will see where you can define a custom schedule for each HBZone (Component #6). If you have multiple program types, merge the zones after defining the schedules separately, but before you connect your HBZones into your daylight simulation component.
