Hi
I have a weird problem in the honeybee
I simulate a building in honeybee and run with 3 different laptops, but the outputs are different in every device and I don’t know why because I didn’t change the file and I run the same file!
Thanks
For an energy model this is strange. Did you try to do a quick comparison of the idf files? Are you sure you’re using the same weather file and the same version of EnergyPlus/OpenStudio?
yes, I used the exact same file and just run with different devices and also the same version of energy plus. I am confused, can I send you my file to check if anything is wrong?
