i would like to make a LB DirectSunHours simulation (if this is the right way) according to DIN EN 17037. Does anyone have a template for me? This would be great.
Kind regards
Hi @michaelzoels,
Did you try to search the forum for “DIN EN 17037”? I believe this has been discussed on the forum a few times.
hi @mostapha ,
yes i tried to search the forum for din en 17037 but i have not found a result. the discussion is the most about the daylight factor and not about the sunlight.
