Does honeybee considers shading impact in recessed window?
I have made recessed window (attached in image). the surrounding walls are different zones.Will honeybee take the shading impact of surrounding wall of other zone for energy results?
Yes. Honeybee and EnergyPlus are capable of calculating the self-shading from the geometry but you should make sure that you set the simulation parameters correctly. I don’t remember what the default shadow calculation is set to but you can see the options here:
