Downgrade Energyplus (IDF) version
I’m trying to create a script to import rhino geometry to TAS 3D through IDF export/import. TAS IDF importer complains that “IDF version 22.3 and above are not supported”. Is there a way to make the ModeltoOSM component generate IDF of a downgraded version? I’ve tried using versioner but it just crashes rhino and doesn’t change anything.
