.eio file and .idf file non existant in EP simulation on Honeybee
Hi all once again, sorry for the bunch of doubts I’m having, this one ocurred during the process of making a simulation on EP, when I tried to plug the result file adress after the simulation ocurred, it shows that it does not exist, does anyone know why?
There’s an image bellow showing when the error ocurred.
Warm regards once again.
Daniel
Here’s the file I’m using in case someone wants to take a look :slight_smile:
ENERGY SIMULATION TEST 06-07.gh (570.3 KB)
Hi @Dconforte,
At my computer it worked well with just a simple box (the geometry was gone). I just had to remove “hourly” because it gave an error.
Did the simulation run propperly. I noticed you did not use the intersect mass component before making zones.
