Electric Light Source with Honeybee and Radiance?
Hi Guys,
First of all thank you so much for the fantastic tool!
I am trying to test how artificial light is getting diffused by an external object.
What would you recommend to do using Honeybee? Is there a way to set up an artificial light source and what sort of visualization should I look for?
Many thanks,
Arthur
Hi Arthur, Thanks-
First, let’s not call it artificial light as it is a real light at the end of the day! I would call it electrical light. :slight_smile:
You can use Honeybee IES2RAD component to insert the light into your scene and everything will be pretty standard Honeybee workflow from there.
You can either render the scene and/or measure the values for a grid based analysis. You can find some examples in this discussion: http://www.grasshopper3d.com/group/ladybug/forum/topics/simulating-…
Mostapha
