I got two errors while running energy plus simulation
Failed to find in library.
Solution exception:‘ascii’ codec can’t encode character ‘\u641’ in position 202: ordinal not in range(128) and when I connect a panel to the output of simulation it says:
{0;0;0}
Current document units is in Meters
Conversion to Meters will be applied = 1.000
Duplicate surface name! Name is changed to: "srfwall_Dup
Duplicate surface name! Name is changed to: "srfwall_Dup_Dup
Duplicate surface name! Name is changed to: "srfwall_Dup_Dup_Dup
Duplicate surface name! Name is changed to: "srfwall_Dup_Dup_Dup_Dup
[1 of 8] Writing simulation parameters…
[2 of 8] Writing context surfaces…
[3 of 8] Writing geometry…
[4 of 8] Writing Electric Load Center - Generator specifications …
[5 of 8] Writing materials and constructions…
[6 of 8] Writing schedules…
[7 of 8] Writing loads and ideal air system…
[8 of 8] Writing outputs…
… idf file is successfully written to : c:\ladybug\unnamed\EnergyPlus\unnamed.idf -
Analysis is running!..
Runtime error (EncoderFallbackException): ‘ascii’ codec can’t encode character ‘\u641’ in position 202: ordinal not in range(128)
Traceback:
line 1566, in writeBatchFile, “”
line 2424, in main, “”
line 2445, in script
