Energy Shade Evaluation error
Hey All,
Thank you for always being so prompt and helpful in all your responses.
I had a question about the shading analysis.
I set up the honeybee wind analysis and it reflected difference in results as expected.
But after setting up the shade evaluation, when I try to simulate it, it does not reflect any difference in results. It also does not show any error.
I probably have missed out on entering some input correctly but I am just not able to figure out what that might be.
I have attached the GH file.
Thank you so much again for all your help.
Regards,
Ghosh
Shell_weather_Wind_Shading_test.gh (667 KB)
Amrita, You should connect a HBObject to EPWindowShades to generate blinds. Right now you are connecting a brep and it doesn’t generate any shading geometries. If you search the group you should find discussions that shows how to use the component.
Thank you so much. It works fine now.
