Hello Guys
I am a student in Efficienty Energy in the construction field
I am trying to use Honeybee and Ladybug to get the Energy Intensity, peak load and temperature of my building.
The teachers could not found the mistake so this is my last time
I selected the different zones but the panels are still nul !!
From the error you get i suggest to do “reverse engineering” and look if your materials/constructions are well defined. Probably not and something is missing in their definitions.
I believe the error message is pretty clear: You are connecting already defined thermal zones while you need to connect just ray geometry (as you just get it from Rhino or GH native components).
Without having your file is hard to say otherwise.
thanks for the great work, I was watching Chris’s videos and well he is great, but I have a little problem. I just attached the pic and the gh file. would you mind to giving me a little help? the analysis I am trying to create is in the 6th video. I am an absolute beginner. I get this error: error.gh (588.5 KB)
I just find out it has a problem with “Honeybee_Glazing based on ratio” component. I made it a little simpler and still it generates an error. If I use “Honeybee_Solve Adjacencies” component it will just make a warning not a fatal error.
