Energy simulation of a breathing building
Hi all ,
I’m working on my master’s Thesis about " the concept of breathing building to cope with climate change " . I’m using responsive kinetic facade which moving according to changing in weather and the needs of users inside the building .
the main goal is to achieve thermal comfort & internal air quality by natural ventilation through the interactive facade .
so I need to know how to optimize the movement of the facade ?
what plug in can I use to get thermal simulation & air movement through building zones?
is there certain steps should I know to achieve my goal ? as I’m new in grasshopper just know basics only :slight_smile:
Thank you
Hi Mona,
It depends how you want to simulate the airflow and what is the question of your thesis.
For thermal simulation you can use Honeybee and it will support what you need. Chris recently developed new components that lets you run studies for airflow changes for simple cases integrated to Energy Simulation but it is limited to what you can do with EnergyPlus (e.g. it is not CFD).
If you want to model airflow between zones with EnergyPlus then you probably want to set up an Airflow Network which we don’t support right now. I don’t know if there is any other plugin to do that but I’m sure other people on the group can help you with that.
Mostapha
PS: I intentionally didn’t use the word natural ventilation, but you can read airflow changes as natural ventilation!
There are people here who could probably answer your question better, but the “air movement” element would be accomplished through Fluid Dynamics (CFD). I’m not sure Honeybee + Ladybug have that capbility yet (I’ve seen talk about it being WIP though). Real CFD work can be extremely sophisticated. I’ve worked with consultants who specialize in it, but have never really engaged it in the Grasshopper realm.
In regards to weather responsive stuff, Lady bug has lots of tools for interacting with local weather data through your local .epw file. That could be combined with some of the radiation tools for building massing.
Sounds like an interesting project. I’d love to see what kind criteria is developed in order to get meaningful kenetic facade behavior.
Thank you Mostapha for your reply ,
I will start using honey bee & ladybug for thermal simulation & for Airflow I will need to model airflow between zones as you mentioned but with another software may be ansys fluent . but first I will see the results of honey bee airflow component by Chris.
Mona,
I think that this discussion already answers a lot of your questions:
http://www.grasshopper3d.com/group/ladybug/forum/topics/thoughts-on…
Let me know if there is anything in there that is missing.
-Chris
thanks Chris , there are so much data about ventilation in that discussion very useful to my research .
