Energyplus not accepting window construction
Hi I’m studying different window constructions for micro climate inside a room .
The below construction gives sever error - Nominal U value is 0. What is the best way to rectify this?
Thank you
Test1.gh (652.4 KB)
Hi @MansiDhanuka,
You have a white space at the end of the name (E304 Window Existing_Thinsulate ). If you delete it, the simulation will run.
Thank you @MohammedAlshayeb
