Energyplus simulation does not generate total thermal loads
I was trying to do a simple simulation but the energyplus engine does not generate the total thermal loads. Can anyone help me to find the problem? Attached is the grasshopper file.Regards
Zuhaib
111.gh (612 KB)
Sheikh,
You probably need to enable a couple more of simulation outputs in the HB_EPOutput (for instance zoneHVACParams_).
Hi Abraham,
I have enabled many simulation outputs. Still the problem exists…
Please have a look on the grasshopper file.
22.gh (600 KB)
Attached a working version.
Just updated (no need to, though).
The main issue was that you set the isConditioned_ at the HB_Mass2Zone to False.
22_AY.gh (616 KB)
Thanks a lot Abraham. Appreciate your help :slight_smile:
Zuhaib
