EP Construction Library Issue
I am using the latest Honeybee components. When I create an EPConstruction Library item it is the library as it should be but when I close the program and re-open it the construction I created is no longer in the library.
Shouldn’t a construction I make remain in the library or must I re-create them every time?
This is how it works. When you create a material/construction and add them to the library they are recognized for the working session. Once you close the file they are “released” from the library.
If your definitions are common and you need to use them frequently i recommend to add them to the userCustomEPLibrary.idf. From there you just need to load them from the permanent library and are ready to use.
A post was split to a new topic: Lighting and equipment load missmatch
