I tried running energyplus and received no errors, but EP did not output a csv file.
Previously, when I ran it, it outputed a csv file, but the “Honeybee read EP results” component could not find it for some reason.
I tried to uninstall a few of the EP versions that had installed with other software, as I thought that might be the cause of the initial problem.
Then I downloaded the EP9.3.0.exe from the github.
Now as I said before, I get no errors, but no csv.
Using HB version 0.0.66 and EP version 9.3.0Processing: TMR6.gh…
