I’m trying to use HB EP Glass Material Component to create an external Film for the window. The Energy Simulation gives a Fatal Error.
The simulation has not run correctly because of this severe error:
** Severe ** CheckAndSetConstructionProperties: Error in window construction E304 WINDOW WITH EX1–
The simulation has failed because of this fatal error:
** Fatal ** GetSurfaceData: Errors discovered, program terminates.
E304MicroClimate_WithMaterials.gh (661.6 KB)
Why is the material not accepted?
Hi @MansiDhanuka,
Is there really no air gap between the two panes of glass? Adding that might work.
Hi @devang
I was trying to add a tinted film to the glass and modeled it without any airspace. Is there another way to model films? Or if you know a way to calculate effective U-value of Glass and film together that I can plug into the EP Window Material component.
Thank you
Yeah. You can calculate that value using Windows. One of the tools from LBNL I am sure you know about.
Okay I will try that thank you.
