Hi i’m here again for asking help…is my frist time on Gh and i start working on it two weeks ago so i’m really sorry if this problem is stupid. On the attached file there is the error during the energy plus silulation and this is the error text:
Current document units is in Meters
Conversion to Meters will be applied = 1.000
Duplicate surface name! Name is changed to: Pelle_Sopra_Dup
Duplicate surface name! Name is changed to: Pelle_Nord_Dup
[1 of 8] Writing simulation parameters…
[2 of 8] No context surfaces…
[3 of 8] Writing geometry…
[4 of 8] Writing Electric Load Center - Generator specifications …
[5 of 8] Writing materials and constructions…
[6 of 8] Writing schedules…
[7 of 8] Writing loads and ideal air system…
[8 of 8] Writing outputs…
… idf file is successfully written to : C:\Users\Personal\Desktop\TESI\x006\THOR001\EnergyPlus\THOR001.idf
Analysis is running!..
C:\Users\Personal\Desktop\TESI\x006\THOR001\EnergyPlus\eplusout.csv
Done! Read below for errors and warnings:
Program Version,EnergyPlus, Version 8.3.0-6d97d074ea, YMD=2016.01.05 20:08,IDD_Version 8.3.0
************* IDF Context for following error/warning message:
************* Note – lines truncated at 300 characters, if necessary…
************* 160 ScheduleTypeLimits,
************* indicated Name=ANY NUMBER
************* Only last 2 lines before error line shown…
************* 161 ANY NUMBER, !- name
************* 162 ScheduleTypeLimits, !-
** Severe ** IP: IDF line~162 Invalid Number in Numeric Field#1 (Lower Limit Value), value=SCHEDULETYPELIMITS, in SCHEDULETYPELIMITS=ANY NUMBER
************* 258 ScheduleTypeLimits,
************* 259 ANY NUMBER, !- name
************* 260 ScheduleTypeLimits, !-
** Severe ** IP: IDF line~260 Invalid Number in Numeric Field#1 (Lower Limit Value), value=SCHEDULETYPELIMITS, in SCHEDULETYPELIMITS=ANY NUMBER
** Warning ** IP: Note – Some missing fields have been filled with defaults. See the audit output file for details.
** Severe ** IP: Possible incorrect IDD File
** ~~~ ** IDD Version:“IDD_Version 8.3.0”
** ~~~ ** Version in IDF=“8.3.0” not the same as expected=“8.3”
** ~~~ ** Possible Invalid Numerics or other problems
** Fatal ** IP: Errors occurred on processing IDF file. Preceding condition(s) cause termination.
…Summary of Errors that led to program termination:
… Reference severe error count=3
… Last severe error=IP: Possible incorrect IDD File
************* Warning: Node connection errors not checked - most system input has not been read (see previous warning).
************* Fatal error – final processing. Program exited before simulations began. See previous error messages.
************* EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors.
************* EnergyPlus Terminated–Fatal Error Detected. 1 Warning; 3 Severe Errors; Elapsed Time=00hr 00min 0.30sec
thanks for any help
Lhor
