Error HB PMV comfort map ” RunEnergySimulation”
Hi, I am receiving the following error while running the PMV comfort map.
I checked old topic about similar error and I used LB versioner but, it didn’t work.
Please help me navigate through it.
Can you share the logs file? You can find it in the path below, or something similar to that if you changed the folder of the simulation.
C:\Users\[USERNAME]\simulation\[MODEL_NAME]\pmv_comfort_map\__logs__\logs.log
Hi Chris! Thank you for replying.
Here is my logs file.
logs.log (240.9 KB)
